Need Some Help (Media)
Old 29-08-2009, 6:22 PM   #1
1,971, Level: 10
Points: 1,971, Level: 10 Points: 1,971, Level: 10 Points: 1,971, Level: 10
Thanks: Gave 1, Got 10
Question Need Some Help (Media)
Ok folks here the problem i cant seem to get my pc to show up on my xbox so i cant play my tunes on my xbox 360.I got windows media player set-up to share my file but it does not work for some reson.Does any one have any now how i can fix this i have tryed everything i can think off.
Old 29-08-2009, 11:00 PM   #2
3,274, Level: 13
Points: 3,274, Level: 13 Points: 3,274, Level: 13 Points: 3,274, Level: 13
Thanks: Gave 28, Got 16
Re: Need Some Help (Media)
1. You must have service pack 2 or 3 on XP (if you're on xp)
2. Disable windows firewall (or set the exceptions for windows media player and windows media player network sharing service)
- Start > Connect to > Show all connections > Right click your internet connection > Properties > advanced > windows firewall settings > select off or, click exceptions > check the boxes marked windows media player and windows media player network sharing service
3. Share your internet connection (if you have the option to)
- Start > Connect to > Show all connections > Right click your internet connection > Properties > advanced > check the box saying 'allow other network users to connect through this computers internet connection' > check the box below saying 'allow other network users to control or disable the shared internet connection'
4. Enable sharing in media player
- Open media player > click the arrow underneath library > click media sharing > click the box marked 'share media to' > select your xbox, then allow
Most people/sites have probhably already told you this so if they have, i apologise
