Xbox Status Code 69-C00D36C4
Old 30-06-2009, 2:20 PM   #1
cybermenace's Avatar
2,088, Level: 10
Points: 2,088, Level: 10 Points: 2,088, Level: 10 Points: 2,088, Level: 10
Activity: 3.3%
Activity: 3.3% Activity: 3.3% Activity: 3.3%
Thanks: Gave 0, Got 2
Anyone else get these whilst trying to stream AVI.files from pc to 360,
I have even started to get them when i have put the video onto my portable device,
they are driving me nuts the problem being sometimes they will play and most of the time i get the status codes...
is there a fix for this???
Bil.
Old 01-07-2009, 1:38 PM   #2
2,088, Level: 10
Activity: 3.3%
Re: Xbox Status Code 69-C00D36C4
I have found a way to get them to play,
I used Xilisoft and rencoded it into a mpeg4 and the all play
Old 03-09-2009, 9:44 PM   #3
3,226, Level: 13
Points: 3,226, Level: 13 Points: 3,226, Level: 13 Points: 3,226, Level: 13
Thanks: Gave 156, Got 59
I am having the same problem. Is it Xilsoft VBideo Convertor? Or is there a free software out there that can do this?
