3.5 million visitors each month
Go Back   AVForums.com > Gaming > Microsoft Console Gaming > Xbox 360 > Xbox 360 Hardware > Xbox 360 HD DVD drive
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
Old 26-12-2006, 11:13 AM   #1 (permalink)
360 HD - was poor audio, now good audio ;-)
I know a few people have commented on this, I only have KK at the moment and played it after a sesh on gears of war. I ddn't alter the volume on the amp but immediately you could tell the sound was quieter and less dynamic sounding.
What is the issue and will there be a fix? I think I read that if a disc has True HD audio as an option on the discs setup menu, then you can select this and the HD drive will decode and output this via the optical connection to the amp?
I'm really not happy with this as it spoils the experience and I don't want to be limited in the future to buying specific discs that have this extra audio option - they should all sound great - what is going on?
MrG99 is offline   Reply With Quote
M1llion (08-02-2007)
Old 26-12-2006, 12:54 PM   #2 (permalink)
Thanks: Gave 9, Got 27
Re: 360 HD - poor audio
There a fixes in the pipeline for the way the 360 decodes the HD soundtracks to DD5.1 & apparently DTS will be added. However currently the 360/HD Drive has no physical capability to offer the new HD sound formats.
These are not available through the optical output and unless MS release a HDMI cable they won't be.
TV Toshiba 37C3030DB Receiver Sony STR-DB790 SAT Sky HD
SD DVD Sony DVPNS76HS MR HD DVD 360 Add on
Console 3 Premiums later i have a 360 Elite & PS3 Speakers Elac Cinema XL
Dazza is offline   Reply With Quote
Old 28-12-2006, 2:17 AM   #3 (permalink)
Johnny Utah's Avatar
Thanks: Gave 6, Got 2
As Dazza said above, the HD-DVD player will never output True HD audio or Dolby Digital + due to the fact that the optical out connection does not have the required bandwidth.
As it stands your HD-DVD's are decoded from their native format and then re-encoded to Dolby Digital 5.1 and sent to your receiver. Therefore no matter what format the particular DVD has, whether it be True HD or Dolby +, you will only have 5.1 sound when played with the xbox player. This could be seen as a step back in terms of audio due to the lack of hdmi connection.
I noticed that when watching king kong, the left and right rear speakers were barely getting sent any sound, i had to place my ear right next to each to make sure they were working at all. The same applied to the Sub, the deep bass sounds during some of the action scenes were not present as you'd expect with 5.1 Dolby (A relatively old format by today's standards). I also noticed like you that the sound was 'flat' and i had to increase the volume substantially before it was at a comfortable level.
I don't yet have any other HD-DVD's to compare with but after reading a few reviews it seems that the HD-DVD player software is not doing a great job of recoding the audio.
Hopefully this future update can resolve this issue (possibly software?) and therefore provide better quality audio!
Johnny Utah is offline   Reply With Quote
Bleem (10-01-2007)
Old 28-12-2006, 11:15 AM   #4 (permalink)
Thanks: Gave 104, Got 153
The 360 is adding dynamic compression to the audio tracks which is like "Midnight Mode" that some amps have that make all the sound the same level, an explosion is only as loud as a conversation.
The 360 can decode TrueHD and in theory will sound better than DD+ even through optical. You will only get proper TrueHD if MS release a HDMI cable or a Component/VGA cable with 5.1 analogue outs.
My Set Up http://www.avforums.com/forums/members-home-cinema-gallery/382398-t8oos-home-cinema.html
Living Room: Panny PTAE900-Sammy 32"-IstarHD-SkyHD-360 Elite-PS3-Wii-Oppo HM31x2-Onkyo SR605-Harmony 895. Bedroom: Sammy 32"-Yammy YSP 800-IstarHD-SkyHD-360 Elite-PS3-Sammy BDP1000-Octava 5x2-Harmony 885. Xbox T8OO PS3 T-8-0-0
T800 is offline   Reply With Quote
Old 28-12-2006, 10:03 PM   #5 (permalink)
Not sure i like the 'sound' of this. There seems no seperation in the channels, almost like 5 channel stereo.
Pointless imho.
Old 28-12-2006, 10:15 PM   #6 (permalink)
Pointless imho.
Dynamic compression is only used for the "Midnight Modes" so people can listen to a 5.1 track at night or just quietly, the 360 is apparently gonna be updated to operate properly.
Imo the seperation is fine, are you sure your amp is set up correctly, I've read lots of problems with the audio but non about seperation.
My Set Up http://www.avforums.com/forums/showthread.php?t=382398
Old 28-12-2006, 11:54 PM   #7 (permalink)
Digicon's Avatar
Thanks: Gave 24, Got 244
I noticed the sound was flat also on KK although only marginally better was the Superman returns True HD track.
Looks like i am investing in a proper HD-DVD Player unless microsoft pulls its finger out.
Digicon is offline   Reply With Quote
Old 29-12-2006, 4:19 PM   #8 (permalink)
Yeah i bought Superman as well just to try it out and it's exactly the same. The sound is flat and the seperation really poor.
I played a SD DVD in my standard player just to make sure that it wasn't the amp.....it wasn't.
The way i understand it (and correct me if i'm wrong) the 360 player uses software to decode the soundtracks rather than a dedicated chip like other generic HD-DVD players. Therefore i guess it would be possible to improve this software.
It's in desperate need of an update!
Old 29-12-2006, 5:16 PM   #9 (permalink)
Digicon's Avatar
Well after many hours of reading on here and various other forums i have decided to Get rid of the 360 drive and buy a dedicated HD-E1 player and new HDMI amp just so i can at least get the Improvement of the Tru HD sound and DD+
Just really dissapointed not picture wise but the sound really makes a difference in a film.
Gonna Keep my 360 for streaming my .TS HD files LOL only thing its good for including playing Games :-)
Old 29-12-2006, 7:02 PM   #10 (permalink)
The add-on for me was just a stop gap until the XE1 is released, unfortunatly it's not even a good stop gap with the audio issue's.
Old 30-12-2006, 9:50 AM   #11 (permalink)
Thanks: Gave 129, Got 83
I'm doing the same... the 360 hd dvd drive will tide me over until a proper 1080p player with an hdmi connection becomes affordable. I have to say I'm fairly happy with the 360 drive for the moment. If Microsoft can fix the audio issues I'll probably hang onto it for a bit longer.
jonathanTVTV is offline   Reply With Quote
Old 30-12-2006, 11:59 AM   #12 (permalink)
HCK
Thanks: Gave 30, Got 38
Originally Posted by Sanborn
Amir I hate to bother you with this question you probably can't answer - but I must.
When is the 360 addon going to have DTS ?
I realize there is a lot of interest in this. All I can say is that the core development work is finished but we need to roll this up in a console update and that takes a bit of time. So I appreciate your patience on this.
The above was taken from the avsforum.....they have been working on this for over a month now....so hopefully we should get the audio fix jan/feb.
ONKYO 605 - Toshiba EP35 HD DVD - Mission 77C1 - Mission M53's - Mission M7DS - Mordaunt Short 309w - Toshiba 37WLT58 - XBOX 360
See my Home Cinema Here...
http://www.avforums.com/forums/members-home-cinema-gallery/325053-cellar-cinema-rags-riches-story.html
HCK is offline   Reply With Quote
Old 30-12-2006, 12:11 PM   #13 (permalink)
MacReady's Avatar
Thanks: Gave 211, Got 60
I have noticed just how flat the sound is and how little the rears seem to be worked when watching MI:III
As others have said, the add on is simply a stop gap for me until I buy a dedicated HD-DVD player and new amp with HDMI v1.3 (when they finally start to appear !) and I am more than happy with the picture it provides....just a bit dissapointed with the sound
My HC set up
My Kit Samsung LE40M87 LCD TV - Onkyo TX SR606 AV Receiver - KEF 2005.2 Speakers - Xbox 360 Elite - XBox HD DVD - Sony PS3 60Gb - Nintendo Wii - Sky + - Sanyo PLV-Z3 - Panoview 6' Screen
XBox Live Gamertag - EndoViper PSN - Endo_Viper
MacReady is offline   Reply With Quote
Old 30-12-2006, 12:17 PM   #14 (permalink)
Quite a few people don't think a DTS update is gonna sort out the problem.
Old 30-12-2006, 12:26 PM   #15 (permalink)
HCK
MS are aware of the problem, Amirm who is part of the HD DVD dev team has said that the fix will be in the DTS update.
http://www.avforums.com/forums/showthread.php?t=325053
360, audio, good, poor
