Faulty xbox premium - loss of video output. Best way to fix?
Old 12-02-2009, 9:46 PM   #1
8,308, Level: 21
Points: 8,308, Level: 21 Points: 8,308, Level: 21 Points: 8,308, Level: 21
Activity: 9.5%
Activity: 9.5% Activity: 9.5% Activity: 9.5%
Thanks: Gave 28, Got 585
My xbox premium console has just started to play up - last night and earlier this evening the video has simply cut-off whilst in the middle of a game. The console isn't freezing completely though as the controls are still responsive & I can hear the audio through my speakers.
I currently have the console connected to my TV with an official MS VGA cable. The last time the video cut out I decided to switch over to the component connection to determine if the problem was with the cable. However, when I try to power it on now I can't get a video signal at all - neither with component or composite. I tried reverting to VGA, but that isn't working now at all either.
Now, because the console isn't actually freezing I'm not getting the RROD - so I know it probably won't be covered by their extended warranty. Does anyone know if there's a simple fix for this? Is it best to just have MS repair it anyway even though I have to pay?
As it happens, I have two xbox consoles. The other one is an elite which I just got back from MS (last Friday!) following a RROD repair. Looks like the xbox gremlins have taken a shine to me!
Old 13-02-2009, 9:58 PM   #2
4,025, Level: 14
Points: 4,025, Level: 14 Points: 4,025, Level: 14 Points: 4,025, Level: 14
Thanks: Gave 70, Got 144
Re: Faulty xbox premium - loss of video output. Best way to fix?
Everything you need to know is here mate -
Screw and washer sizes for rrod
Old 14-02-2009, 9:23 AM   #3
Location: Real guitars don't have strings, they have 5 coloured buttons.
28,493, Level: 41
Points: 28,493, Level: 41 Points: 28,493, Level: 41 Points: 28,493, Level: 41
Activity: 12.9%
Activity: 12.9% Activity: 12.9% Activity: 12.9%
Thanks: Gave 616, Got 940
Another failure of the ANA or HANA chip.
Something is up.
