Xbox 360 backup
Old 02-02-2009, 8:20 AM   #1
4,581, Level: 16
Points: 4,581, Level: 16 Points: 4,581, Level: 16 Points: 4,581, Level: 16
Thanks: Gave 16, Got 20
Xbox 360 backup
Hi all, is there any way of backing up my xbox 360 HDD?
Regards
Tom
Old 02-02-2009, 9:39 AM   #2
50,193, Level: 54
Points: 50,193, Level: 54 Points: 50,193, Level: 54 Points: 50,193, Level: 54
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,070, Got 2,048
Re: Xbox 360 backup
Any particualr elements? Games saves I assume, as everything else can be re-downloaded at no charge. I believe there's a device called X-Sata that connects to a PC that may be what you're after.
Old 02-02-2009, 9:53 AM   #3
13,517, Level: 27
Points: 13,517, Level: 27 Points: 13,517, Level: 27 Points: 13,517, Level: 27
Activity: 8.4%
Activity: 8.4% Activity: 8.4% Activity: 8.4%
Thanks: Gave 95, Got 206
Re: Xbox 360 backup
I bought one of these by Team Xecuter.
Works a treat.
Old 02-02-2009, 9:56 AM   #4
10,589, Level: 24
Points: 10,589, Level: 24 Points: 10,589, Level: 24 Points: 10,589, Level: 24
Thanks: Gave 196, Got 244
Re: Xbox 360 backup
A memory card is the easy option. Used one to transfer my save games when I got a Elite concole.
Mark..
Old 02-02-2009, 11:54 AM   #5
5,808, Level: 18
Points: 5,808, Level: 18 Points: 5,808, Level: 18 Points: 5,808, Level: 18
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 417, Got 472
Re: Xbox 360 backup
Has anyone with the X-SATA actually tried a 'restore' of anything? Did it work? I've hear horrible things about them.
Old 02-02-2009, 12:32 PM   #6
Location: Real guitars don't have strings, they have 5 coloured buttons.
28,493, Level: 41
Points: 28,493, Level: 41 Points: 28,493, Level: 41 Points: 28,493, Level: 41
Activity: 12.9%
Activity: 12.9% Activity: 12.9% Activity: 12.9%
Thanks: Gave 616, Got 940
Re: Xbox 360 backup
I've also heard they suck.
I've heard that unless you restore to the HDD it came off it doesn't work, and chances are you would want to restore onto a different HDD.
Old 03-02-2009, 12:09 AM   #7
5,023, Level: 16
Points: 5,023, Level: 16 Points: 5,023, Level: 16 Points: 5,023, Level: 16
Activity: 4.1%
Activity: 4.1% Activity: 4.1% Activity: 4.1%
Thanks: Gave 109, Got 518
Re: Xbox 360 backup
I use the official MS 120gb Transfer Cabl and xplorer360 extreme.
