can someone help!!!
Old 27-01-2009, 9:23 PM   #1
2,235, Level: 10
Points: 2,235, Level: 10 Points: 2,235, Level: 10 Points: 2,235, Level: 10
can someone help!!!
hi all hope someone can help with this ive bought the x4 headset from the usa and need someone to help me! i need a converter from usa plugs to uk plug the power output of the headphones are 9vdc @ 360ma(100vac-240ac) can someone tell me what kind of converter i will need to run the set without burning it out? and maybe where i could get it from? anyhelp would be great thank you!!
Old 28-01-2009, 7:51 AM   #2
4,023, Level: 14
Points: 4,023, Level: 14 Points: 4,023, Level: 14 Points: 4,023, Level: 14
Thanks: Gave 70, Got 144
Re: can someone help!!!
You dont Scott. As it says 100-240v its a voltage switching psu. 100 to 240 is the full range. The UK uses 240v.
Just like the PS3's psu.
Old 28-01-2009, 12:22 PM   #3
2,235, Level: 10
sorry if this is a silly question but what does psu mean? does the mv or amps not hav to be taken into account?? so all i would need is a plug for the usa plug to fit into uk plug? thanks for your help!! am just worried i spend my money only to blow the thing up!!
Old 28-01-2009, 12:24 PM   #4
5,868, Level: 18
Points: 5,868, Level: 18 Points: 5,868, Level: 18 Points: 5,868, Level: 18
Activity: 5.4%
Activity: 5.4% Activity: 5.4% Activity: 5.4%
Thanks: Gave 178, Got 331
Power supply unit............. I suspect
Old 28-01-2009, 12:28 PM   #5
mossym's Avatar
Location: You'd get your feet wet getting here, but the Guinness is worth it...
24,850, Level: 38
Points: 24,850, Level: 38 Points: 24,850, Level: 38 Points: 24,850, Level: 38
Activity: 11.8%
Activity: 11.8% Activity: 11.8% Activity: 11.8%
Thanks: Gave 598, Got 1,310
yup, all you need is the plug adapter. As long as it says 100-240V you are fine.
Old 28-01-2009, 12:29 PM   #6
2,235, Level: 10
so it will be ok to plug straight in? anyone else doen this before? thanks
Old 28-01-2009, 1:04 PM   #7
4,023, Level: 14
Yep, you'll be fine mate. I just used the PS3 as an example. The power supply unit in that say 100-240 so it accepts the full range. The xbox 360 on the other hand has 240v uk psu's, and 110v ones for USA/Japan.
Your headset is the same, a multi voltage switching psu.
Old 28-01-2009, 1:21 PM   #8
mossym's Avatar
24,850, Level: 38
Activity: 11.8%
yup, lived in the states for a good while, moved home and anything i had over there that said 100-240 was plugged straight into the wall here and works.
Old 28-01-2009, 8:27 PM   #9
2,235, Level: 10
Thank you everyone for your help!
Old 28-01-2009, 9:40 PM   #10
4,023, Level: 14
You didn't get fried?
Phew, thank god for that
