Faulty xbox 360
Old 14-12-2008, 6:07 PM   #1
2,769, Level: 12
Points: 2,769, Level: 12 Points: 2,769, Level: 12 Points: 2,769, Level: 12
Thanks: Gave 19, Got 0
Faulty xbox 360
I have been offered a 360 with everything for £30, only problem is it no longer reads the discs. My mate tried to change the case to a black one and it stopped working, until then it worked fine. What do you guys reckon the problem is
Old 14-12-2008, 6:42 PM   #2
2,596, Level: 11
Points: 2,596, Level: 11 Points: 2,596, Level: 11 Points: 2,596, Level: 11
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 30, Got 29
Re: Faulty xbox 360
unsure about what the problem could be but you could buy a new dvd drive for it, they sell for about £30-£40 depending on what brand you get . Althought you would need to know how to flash the new dvd drive with the key for it to work
Old 14-12-2008, 6:56 PM   #3
2,769, Level: 12
Re: Faulty xbox 360
Someone said they will fit it for £25
Old 15-12-2008, 11:14 PM   #4
4,023, Level: 14
Points: 4,023, Level: 14 Points: 4,023, Level: 14 Points: 4,023, Level: 14
Thanks: Gave 70, Got 144
Re: Faulty xbox 360
If the only problem is it's not reading discs a new laser costs about 12 quid, and it's a 10 minute change over job.
Give me more details on it's symptoms now. Does it boot up? Any red lights etc?
