Xbox 360 Jasper Console (Speculation & Info in here please)
Thread Closed
Old 24-08-2009, 10:03 AM   #1111
Illustrious Member
45,786, Level: 52
Points: 45,786, Level: 52 Points: 45,786, Level: 52 Points: 45,786, Level: 52
Activity: 95.8%
Activity: 95.8% Activity: 95.8% Activity: 95.8%
Thanks: Gave 1,840, Got 3,265
Re: Xbox 360 Jasper Console (Speculation & Info in here please)
Originally Posted by spurssimon View Post
so the arcade ive got arriving this week from argos.co.uk should damn well be a jasper yeah????? considering its been out of stock for home delivery
You will be able to check before you open it via the flap on the back of the box, where you can poke it through and look for the tell tale signs (search thisthread as it has been stated so many times)
Otherwise you may/should be able to send it back and order another one to get a jasper (if you are that desperate)
@ Anthony (+ others that discussed it): Sorry i forgot to send that PM to a mod the other day regarding editing the OP, will do it now
Old 24-08-2009, 2:16 PM   #1112
1,282, Level: 8
Points: 1,282, Level: 8 Points: 1,282, Level: 8 Points: 1,282, Level: 8
Thanks: Gave 11, Got 16
Wink Re: Xbox 360 Jasper Console (Speculation & Info in here please)
How many people on here have Japser Consoles?
Will any of the rumoured bundles make the UK?
Old 24-08-2009, 2:30 PM   #1113
Illustrious Member
45,786, Level: 52
Activity: 95.8%
A fair amount have jaspers i believe, i have one for starters
And mostly people come to this thread to find out how to identify a jasper for when they buy one
What do you mean rumoured bundles?
If you follow all the rumours that are circulating you will be very lost
Old 25-08-2009, 7:57 AM   #1114
Moderator/Games Reviewer
46,390, Level: 52
Points: 46,390, Level: 52 Points: 46,390, Level: 52 Points: 46,390, Level: 52
Activity: 6.8%
Activity: 6.8% Activity: 6.8% Activity: 6.8%
Thanks: Gave 468, Got 1,372
1000+ posts closing thread Part 2 here
Thread Closed
