Bit more info on BT vision on xbox360..
Old 29-11-2008, 12:09 PM   #1
12,765, Level: 27
Points: 12,765, Level: 27 Points: 12,765, Level: 27 Points: 12,765, Level: 27
Thanks: Gave 267, Got 265
BT Vision to get high-performance make-over in 2009, but closes door on Freesat | Home Cinema Choice
‘You're going to be able to access, using the Xbox 360, our on-demand content. BT Vision's on-demand EPG is going to be integrated into Xbox 360, so you can switch between on-demand programmes and games.'
From your Xbox 360, you'll also be able to access PVR content from a V-Box in another room.
Old 01-12-2008, 1:08 AM   #2
4,708, Level: 16
Points: 4,708, Level: 16 Points: 4,708, Level: 16 Points: 4,708, Level: 16
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
Thanks: Gave 14, Got 3
Re: Bit more info on BT vision on xbox360..
I am afraid that they will require BT broadband and more strings attached.
Why so cool european commissioners that fined microsoft for not sharing code of Vista kernel with lousy european businesses are so silent? Why cant we just buy a movie and enjoy it? It is a 21st century after all!
Old 01-12-2008, 9:18 AM   #3
3,253, Level: 13
Points: 3,253, Level: 13 Points: 3,253, Level: 13 Points: 3,253, Level: 13
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 157, Got 160
It also requires a very close distance to your exchange, I tried to get bt vision earlier in the year and i was told that they didn't detect a broadband connection on our line and we needed broadband! I kindly informened them that we were paying them for broadband. Apparently are line is bad quality and has too many drops for btvision to work on.
Old 01-12-2008, 9:28 PM   #4
12,765, Level: 27
I have btvision and its great, but i do get 8mb broadband as im only 500m from the exchange
Before i was with bt broadband i was with pipex and i never got more than 300k/sec download speeds i get 800kb/sec now with bt..(same line, same flat)
