Error Code E79 - Help
Old 27-11-2008, 3:28 PM   #1
4,156, Level: 15
Points: 4,156, Level: 15 Points: 4,156, Level: 15 Points: 4,156, Level: 15
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
Thanks: Gave 136, Got 95
Hi my sons console has been freezing and now he has the error code E79 - is it terminal???? help please
Old 27-11-2008, 3:44 PM   #2
9,201, Level: 22
Points: 9,201, Level: 22 Points: 9,201, Level: 22 Points: 9,201, Level: 22
Activity: 19.7%
Activity: 19.7% Activity: 19.7% Activity: 19.7%
Thanks: Gave 359, Got 255
Re: Error Code E79 - Help
Not sure if this will help welly:
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
According to tmbinc: E79 is the error code if xam.xex could not be started, i.e. probably a file system corruption.
Got this after doing a google.
Old 27-11-2008, 4:01 PM   #3
43,182, Level: 50
Points: 43,182, Level: 50 Points: 43,182, Level: 50 Points: 43,182, Level: 50
Activity: 48.5%
Activity: 48.5% Activity: 48.5% Activity: 48.5%
Thanks: Gave 3,072, Got 3,157
Computer says no !
Old 27-11-2008, 4:21 PM   #4
4,156, Level: 15
Activity: 1.8%
hi did that and now got a E71 now its just all freezing HELP
Old 27-11-2008, 4:33 PM   #5
10,858, Level: 25
Points: 10,858, Level: 25 Points: 10,858, Level: 25 Points: 10,858, Level: 25
Thanks: Gave 285, Got 357
Give the following a try, if this doesn't help theres nothing that can be done i'm afraid
1. With the console off, press and hold the sync up button (the small white one)
2. While holding the sync button press the power button to turn on the console
3. Continue to hold the sync button until the Console has booted up completely.
4. During the boot process the console should clear any failed updates, allowing you to use it normally.
Old 27-11-2008, 6:04 PM   #6
4,156, Level: 15
Activity: 1.8%
hi thank you for your advice - I have done that - we are not getting the error code now but the same/screen is freezing at different points in the game.
Old 27-11-2008, 7:21 PM   #7
10,858, Level: 25
Sounds like the GPU could possibly be on its way out so i would suggest either returning the console to the store if it was purchased less than a year ago or arranging a repair by microsoft. If you take the Microsoft route make sure you tell them your getting the 3 red lights or they will try and charge you.
Old 28-11-2008, 6:48 AM   #8
4,023, Level: 14
Points: 4,023, Level: 14 Points: 4,023, Level: 14 Points: 4,023, Level: 14
Thanks: Gave 70, Got 144
E71 is a failed dashboard update. Were you updating at the time?
Old 28-11-2008, 9:19 AM   #9
10,858, Level: 25
The OP isn't getting E71 anymore, he clearly stated this 2 posts above
Old 28-11-2008, 9:27 AM   #10
4,023, Level: 14
Sorry, can you forgive me?
Old 28-11-2008, 10:55 AM   #11
4,156, Level: 15
Activity: 1.8%
Hi there is no codes now , just turns on and then freezes.
Old 28-11-2008, 11:00 AM   #12
4,752, Level: 16
Points: 4,752, Level: 16 Points: 4,752, Level: 16 Points: 4,752, Level: 16
Activity: 12.0%
Activity: 12.0% Activity: 12.0% Activity: 12.0%
Thanks: Gave 32, Got 27
Im sorry to report that this error is fatal and needs to be fixed by Microsoft,hopefully its in warranty
Old 28-11-2008, 11:02 AM   #13
4,156, Level: 15
Activity: 1.8%
Originally Posted by kev. View Post
I got the console in a trade a few months ago,so not sure about warranty.
Old 28-11-2008, 12:04 PM   #14
10,858, Level: 25
I'm afraid not mate, completely unforgivable
Old 28-11-2008, 12:21 PM   #15
4,156, Level: 15
Activity: 1.8%
Is there anyway i can check if it still has warrenty??
Old 29-11-2008, 5:22 PM   #16
3,076, Level: 13
Points: 3,076, Level: 13 Points: 3,076, Level: 13 Points: 3,076, Level: 13
Thanks: Gave 83, Got 87
Go to to your live profile page, go to support, register your console (assuming you haven't already done so) and there is a link on the right side of the page called "warranty status".
Old 29-11-2008, 9:29 PM   #17
4,156, Level: 15
Activity: 1.8%
Trying to register my console on xbox site and as i have complete the form i have put the united kingdom and it won't submit it says
  • The chosen country is not currently supported.
Why it doing this???????????
Old 30-11-2008, 11:03 AM   #18
4,156, Level: 15
Activity: 1.8%
help
Old 30-11-2008, 1:14 PM   #19
3,076, Level: 13
There should be a link at the top left corner of the page which says "international". Click on that and you should be able to go to the UK Xbox site.
What you're currently trying to do is register a UK console on the US website (I did exactly the same thing).
Old 30-11-2008, 2:03 PM   #20
4,156, Level: 15
Activity: 1.8%
thank you - i have registered it now and booked a repair - thank you for your help
Old 30-11-2008, 2:21 PM   #21
3,076, Level: 13
My pleasure.
Old 30-11-2008, 2:25 PM   #22
4,156, Level: 15
Activity: 1.8%
My pleasure.
I thought i was going crazy when it wasn't working, and it is still in warrenty aswell, so chuffed with that. Thanks for all your help
