I want to paint my chatpad black. Help required.
Old 13-11-2008, 6:38 PM   #1
9,959, Level: 23
Points: 9,959, Level: 23 Points: 9,959, Level: 23 Points: 9,959, Level: 23
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 119, Got 172
As title, I would like my chatpad to be black to match my controller and xbox elite. I have been looking around the web for info on how to do this and have found it is best to dye the plastic rather than paint it. Anyway I have been told to use vinyl dye to turn the plastic white.
I have found this product on ebay but am unsure if it is the correct stuff.
Magix Colour Spray Dye Leather & Vinyl Black 317 on eBay, also, Shoe Repair, Clothing Shoe Care, Clothes, Shoes Accessories (end time 06-Dec-08 01:26:57 GMT)
Can anybody advise?
Old 13-11-2008, 7:07 PM   #2
4,024, Level: 14
Points: 4,024, Level: 14 Points: 4,024, Level: 14 Points: 4,024, Level: 14
Thanks: Gave 70, Got 144
Re: I want to paint my chatpad black. Help required.
I would just use an acrylic primer first, then regular car spray paint.
In my experience the die method comes out patchy.
Sandman (13-11-2008)
Old 13-11-2008, 7:38 PM   #3
9,959, Level: 23
Activity: 2.4%
Thanks I will give that a go tomorrow then and see what happens.
