Is there anyway of an xbox just curing itself after RROD (no towels though please)
Old 12-11-2008, 5:28 PM   #1
7,988, Level: 21
Points: 7,988, Level: 21 Points: 7,988, Level: 21 Points: 7,988, Level: 21
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 915, Got 208
Well just got RROD after the xbox freezing on the dashboard but i turned off straight away when i saw the RROD and im not going to turn it on for a while well before i get my hopes up is this permanent or should i keep waiting and leave till tommorow and hope for the best just as well ive been able to give GOW2 a go it just sucks that its red rings half way through the week instead of on saturday ready for a monday pick up.
Old 12-11-2008, 5:29 PM   #2
mossym's Avatar
Location: You'd get your feet wet getting here, but the Guinness is worth it...
24,859, Level: 38
Points: 24,859, Level: 38 Points: 24,859, Level: 38 Points: 24,859, Level: 38
Activity: 12.2%
Activity: 12.2% Activity: 12.2% Activity: 12.2%
Thanks: Gave 598, Got 1,311
Re: Is there anyway of an xbox just curing itself after RROD (no towels though please
even if it recovers it is not going to last long...i'm afraid it's going back
Old 12-11-2008, 5:31 PM   #3
7,988, Level: 21
Activity: 0.7%
I was just thinking it may have been due to the dashboard freezing o well ill have to be demoted to ps3 NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Old 12-11-2008, 5:39 PM   #4
mossym's Avatar
24,859, Level: 38
Activity: 12.2%
not the dashboard if you got 3 rrod
Old 12-11-2008, 8:27 PM   #5
4,025, Level: 14
Points: 4,025, Level: 14 Points: 4,025, Level: 14 Points: 4,025, Level: 14
Thanks: Gave 70, Got 144
Eh?
The solder used under the chips on the motherboard is moving and then setting during average use, so when it got too hot either the cpu, gpu, or one of the 4 ram chips lost contact, and you got the 3 red lights.
It all cools down, contact is remade between chip and motherboard, and it works again.
In theory.
But once the solder starts it's shift, it needs reflowing, and the end is imminent i'm afraid.
Are you in warranty, as it will have to go in for repair?
Old 12-11-2008, 9:04 PM   #6
7,988, Level: 21
Activity: 0.7%
Yep this is a refurb and i got an xbox near launch jan '06. atm its stopped flashing so theres no returning that can be done and im not going to force it in to RROD because of mirrors edge and GOW2
Old 12-11-2008, 10:38 PM   #7
mossym's Avatar
24,859, Level: 38
Activity: 12.2%
Eh?
he said he thought it was due to the dashboard freezing, just pointing out it wasn't
Old 12-11-2008, 11:18 PM   #8
4,025, Level: 14
The dashboard freezing is due to the solder balls unseating under the gpu, which will then give you the 3 red lights, and probably an E74 error.
Old 13-11-2008, 8:46 PM   #9
7,988, Level: 21
Activity: 0.7%
I was hoping that the fact that it only RROD after turning it off and on instantly was the cause and triggered the RROD which mainly happens after what you wrote but i guess it can mean other things as it is an unknown hardware error message.
Old 13-11-2008, 9:39 PM   #10
4,025, Level: 14
There's only a couple of unknown ones mate, the E74 is one of the most common, and certainly one of the easiest to fix -
Xboxexperts.com Xbox 360 Repair/Modding - E74/1022
Old 14-11-2008, 11:12 PM   #11
7,988, Level: 21
Activity: 0.7%
Yep thats it got the permanent RROD off to microsoft it goes whats the average time it takes to repair IIRC its two weeks
Old 14-11-2008, 11:26 PM   #12
7,994, Level: 21
Points: 7,994, Level: 21 Points: 7,994, Level: 21 Points: 7,994, Level: 21
Thanks: Gave 285, Got 496
I sent mine back with an intermittent RROD, it wasn't doing it when I sent it off and they just replaced it with a new (HDMI) console. It was back within 7 days - suppose it depends how busy they are etc. Best do it now, I've a feeling a lot of people will be switching on old xbox's when NXE arrives so they might get busy.
wellladida (15-11-2008)
Old 15-11-2008, 8:59 AM   #13
7,988, Level: 21
Activity: 0.7%
7 days and a new HDMI xbox sounds nice yep and i suppose the NXE might start xbox getting busy will be phoning xbox today
Old 15-11-2008, 10:31 AM   #14
7,988, Level: 21
Activity: 0.7%
And if the RROD is intermitent and when xbox recieve my 360 and its playing ok will they just send it back
Old 20-11-2008, 7:51 PM   #15
7,988, Level: 21
Activity: 0.7%
Is off tommorow just after nxe comes out and i didnt get to try it oh well hopefully i should have mine back next week
Old 20-11-2008, 8:59 PM   #16
6,799, Level: 19
Points: 6,799, Level: 19 Points: 6,799, Level: 19 Points: 6,799, Level: 19
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 256, Got 293
Mine RROD'd then came back to life. It was very short lived though and it died again within days, luckily I have a friend who is god of all things xbox, he did the xclamp fix and all was fine again, few months later got RROD again. He stripped the motherboard out, took all the bits he could off it wrapped everything but the chips in tin foil and stuck it in the oven for about five mins. Sounds scary but it's been fine ever since. Couldn't send to microsoft because of warranty issues.
Old 20-11-2008, 9:07 PM   #17
4,025, Level: 14
Not a good move as you are baking the capacitors. The areas that need heating should be isolated.
Tell him to use a heatgun next time.
Right idea though
Old 22-11-2008, 12:52 PM   #18
6,799, Level: 19
Activity: 3.0%
Right idea though
It can't have been that bad a move since its woked perfectly since.
Old 16-12-2008, 4:07 AM   #19
2,349, Level: 11
Points: 2,349, Level: 11 Points: 2,349, Level: 11 Points: 2,349, Level: 11
Activity: 3.0%
Thanks: Gave 31, Got 63
There are a few causes and effects that make RROD rear its head.
Placement of your console: if you put it on your carpet your asking for it to happen, in all honesty Microsoft didn't give it adequate cooling vents to vent the air out so it needs as much room to breath as possible.
Sometimes having it sideways on can cause it due to the weight of the CPU heatsink pushing down on 2 corners of the CPU chip.
Dust: this is not the Xbox's best friend lol!
Dropping your console: one way to cause it
The towel trick: lol if you try this your asking for your console to die.
The main errors are 2 red lights which is overheating, most likely fan failure or thermal compound breakdown between the heatsinks and CPU/GPU die's.
1 Red light E74 Which is cold solder of the ANA chip and requires reflow
There are other errors on this one light but thats the main one, others can include E64 which is a bad flash for those special kinda games.
3 Red Lights, CPU/GPU Solder balls loosing contact with the motherboard due to heat expantion and cooling contraction, can also be caused by your power supply not being plugged in snuggly and if you get 4 you might wanna plug in your av leads
Ive experienced all of them as I repair xbox's for a living
Old 16-12-2008, 7:00 AM   #20
4,025, Level: 14
Mate, so far there are about 60 known causes of 3 red lights.
This may help you -
Xboxexperts.com Xbox 360 Repair/Modding - Errorcode Overview
What's with all these comedy posts?
Old 16-12-2008, 2:57 PM   #21
2,349, Level: 11
Activity: 3.0%
This may help you -
What ive posted are the most common
Old 20-12-2008, 9:51 PM   #22
10,265, Level: 24
Points: 10,265, Level: 24 Points: 10,265, Level: 24 Points: 10,265, Level: 24
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 176, Got 148
My elite rrod twice while playing cod waw, switched it off and started up fine after both occasions, not happened for about a month now, but i do expect it to die on me some time in the future.
Old 26-12-2008, 12:25 PM   #23
Bonesy's Avatar
6,248, Level: 18
Points: 6,248, Level: 18 Points: 6,248, Level: 18 Points: 6,248, Level: 18
Activity: 1.0%
Thanks: Gave 16, Got 8
I had it twice the other day, now working fine, but I guess I should return it.
anyone know how? do I ring microsoft direct?
