usb to optical cable thingy
Old 10-11-2008, 6:16 PM   #1
2,436, Level: 11
Points: 2,436, Level: 11 Points: 2,436, Level: 11 Points: 2,436, Level: 11
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 5, Got 1
hello everyone.
silly question, but is there a way to plug usb into a thing and have an optical cable come out if it. i have a xbox 360 with the HD player but my surround sound box does not have a hdmi input slot just optical and coxial. i do use the xbox vga cable that has optical output. but i perfer hdmi video display. i think if i use usb from the back of the hd player that would transfer sound, i hope?
Old 12-11-2008, 11:30 PM   #2
Illustrious Member
30,262, Level: 42
Points: 30,262, Level: 42 Points: 30,262, Level: 42 Points: 30,262, Level: 42
Activity: 25.3%
Activity: 25.3% Activity: 25.3% Activity: 25.3%
Thanks: Gave 53, Got 1,273
Re: usb to optical cable thingy
Originally Posted by Seven_Legs View Post
hello everyone.
Afraid not, what you need is to break the case off the VGA cable so that you can plug it and the HDMI cable in at the same time, that way you will get the best video and also be able to connect optical.
If you dont want to break the case of the cable though, you can always buy the MS Audio Dongle.
Old 13-11-2008, 3:46 PM   #3
2,436, Level: 11
Activity: 2.4%
thanks for that. i ordered one from ebay. i am glad cause i like the 1080p hdmi over the vga.
