HD DVD drive/PC/Multi-region
Old 04-09-2008, 7:45 PM   #1
biroman13
Posts: n/a
This may have been covered already but I'm a little confused to say the least!
I understand that the HD DVD drive isn't region encoded but the X-box is. What I'm unclear on is if I connect the drive to my PC instead (and from there to the TV) will I be able to play region 1 dvds and will it lock my drive to that region so if I then connect it to my xbox again I'm stuck with that region?
Hope that makes sense and hope someone can help!
Old 07-09-2008, 1:24 PM   #2
1,955, Level: 10
Points: 1,955, Level: 10 Points: 1,955, Level: 10 Points: 1,955, Level: 10
Thanks: Gave 13, Got 24
Re: HD DVD drive/PC/Multi-region
It is the PC's Windows version region for DVD that changes not the actual drive - if you put in a region 1 windows will prompt to change the region and tell you how many changes you have left (in windows) . You can use DVD4free or anydvd to get round this limitation of windows.
For instance Linux doesnt care about regions - it will play discs from any region using the xbox360 add on (or any DVD-Rom drive).
When the add on is attached to the 360 you are then restricted to region 2 or region free discs.
