Originally Posted by Delvey and i wouldnt
its cheap, the dvd's are cheap and most the same quality of blu-ray (he'll probably disagree, but ive seen 300 on both and there is no difference)
most dvd's are £5, and there are 100's of titles, so i would say go for it |
Actually, *he* won't disagree. I have an Xbox 360 with the HD-DVD add-on AND a standalone blu-ray player, and in terms of quality, I can't say as I notice a difference either.
Both Delvey and Pricklespons are right; quality difference is negligible in most cases, and there are plenty of cheap HD-DVD's on the market.
That said, I personally still wouldn't bother buying into a technology thats discontinued. New movies will end up not being produced on the format, and if you want to continue to collect new films in a HD format, you'll *have* to get a blu-ray player eventually. Meaning you'll end up with 2 systems, and 2 separate movie libraries.
Perhaps none of this is an issue for you, in which case, ignore everything I've said and go for it!
After all, its not like its a fortune...
Ultimately, its just personal choice!
