HD-DVD drive on Macs
Old 18-07-2008, 4:41 PM   #1
Cujo101's Avatar
5,585, Level: 17
Points: 5,585, Level: 17 Points: 5,585, Level: 17 Points: 5,585, Level: 17
Thanks: Gave 29, Got 27
Does anyone know if it is possible to run HD-DVD's on Mac OS 10.5 using the 360 HD-DVD drive.
Old 18-07-2008, 11:01 PM   #2
1,622, Level: 9
Points: 1,622, Level: 9 Points: 1,622, Level: 9 Points: 1,622, Level: 9
Thanks: Gave 1, Got 2
Re: HD-DVD drive on Macs
Hardware-wise. Yeah. Just plug it in and OS X knows exactly what it is.
Software..... No. If you put a HD-DVD in, it loads up DVD Player.app, but it doesn't know what to do with it, and, as far as i'm aware, there aren't any programs that allow the playing of HD-DVD disks
Old 07-09-2008, 6:42 PM   #3
2,188, Level: 10
Points: 2,188, Level: 10 Points: 2,188, Level: 10 Points: 2,188, Level: 10
Thanks: Gave 0, Got 2
There's currently no way of playing back HD-DVD movies in OSX.
Old 22-09-2008, 7:56 PM   #4
3,818, Level: 14
Points: 3,818, Level: 14 Points: 3,818, Level: 14 Points: 3,818, Level: 14
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 6, Got 18
hopefully they'll be adding that capability soon, probably not in Snow Leopard but the next version of OS X
