Where can I get PowerDVD v7 cheap?
Old 06-07-2008, 10:52 PM   #1
4,141, Level: 15
Points: 4,141, Level: 15 Points: 4,141, Level: 15 Points: 4,141, Level: 15
Does anyone know of anyplace that still sells PowerDVD v7 cheap?
Old 07-07-2008, 11:01 PM   #2
cjed's Avatar
2,399, Level: 11
Points: 2,399, Level: 11 Points: 2,399, Level: 11 Points: 2,399, Level: 11
Activity: 18.9%
Activity: 18.9% Activity: 18.9% Activity: 18.9%
Thanks: Gave 17, Got 49
Re: Where can I get PowerDVD v7 cheap?
If you mean PowerDVD v7, for just DVD and media file playback then Scan will sell you an OEM version for under £5. However, if you mean PowerDVD Ultra V7 to play back Blu-Ray and HD-DVD, then you'll have to pay around £50.
Personally, I'd recommend Arcsoft's TotalMedia Theatre over PowerDVD, it's been much more stable on my system than PowerDVD V7 ever was, and uses much less CPU than Nero Showtime's Blu-Ray/HD-DVD add-on.
Old 08-07-2008, 11:34 AM   #3
Illustrious Member
40,970, Level: 49
Points: 40,970, Level: 49 Points: 40,970, Level: 49 Points: 40,970, Level: 49
Activity: 29.4%
Activity: 29.4% Activity: 29.4% Activity: 29.4%
Thanks: Gave 278, Got 1,647
Does the latest TotalMedia do HD DVD? If not what version did? I may try it over PowerDVD 7.3.
Old 08-07-2008, 6:01 PM   #4
cjed's Avatar
2,399, Level: 11
Activity: 18.9%
The latest certainly does (Version: 2.1.6.113) - and I think all versions have. There's a try-before-you-buy version you can download to check it's compatible with your system.
Old 08-07-2008, 7:04 PM   #5
Illustrious Member
40,970, Level: 49
Activity: 29.4%
I tried it earlier unfortunately the picture was very stuttery and unwatchable. I have to stick with PowerDVD 7.3 for now. It did look nice though (and very like powerdvd).
