HD-DVD Problems
Old 03-07-2008, 6:04 PM   #1
5,258, Level: 17
Points: 5,258, Level: 17 Points: 5,258, Level: 17 Points: 5,258, Level: 17
Thanks: Gave 51, Got 10
HD-DVD Problems
Hi folks
I bought a new HD-DVD drive for my 360 last week. It all started great - I watched Iwo Jima with no probs at all. However, I then played Transformers that I received through Lovefilm and I found it to be jerky to the point where it actually froze. When I rebooted the HD-DVD would not play *any* HD films - SD DVDs played with no probs at all.
Sods law, I took it back and it all worked fine for a week and just today I played Full Metal Jacket, which again froze, rebooted, nothing worked, gave it about 3 hours and it all works fine...?!?!
The shop say they will do a swap in case it is the drive but was wondering if anyone had had similar problems?
Old 04-07-2008, 12:13 PM   #2
2,676, Level: 12
Points: 2,676, Level: 12 Points: 2,676, Level: 12 Points: 2,676, Level: 12
Thanks: Gave 7, Got 35
Re: HD-DVD Problems
My one would occasionally go all blocky when watching Phantom of the Opera. Never could figure out what was causing
Old 04-07-2008, 3:56 PM   #3
5,456, Level: 17
Points: 5,456, Level: 17 Points: 5,456, Level: 17 Points: 5,456, Level: 17
Thanks: Gave 168, Got 326
Re: HD-DVD Problems
People have had problems with cookies etc I believe, in the 360 dashboard delete everything from the HD-DVD drive and try the films that don't work again.
Old 05-07-2008, 9:58 AM   #4
5,258, Level: 17
Re: HD-DVD Problems
cheers sordid, will give it a go
