Originally Posted by tobybunny Just wondering if it's possible to update the X-Box HD Drive without having an X-Box 360 console .
I have mine plugged into my PC via USB as it is great for not only playing HD-DVDs but also gives me two extra usb ports to attach my external HDD to.
I have tried with the cd rom but this is obviously intended for use with the xbox console.
I have updated dvd drives etc with firmware , can you do the xbox hd drive the same way or is it possible only when connected to the console ? |
Hi Tobybunny
As far as I know you have to be joined to the XBox 360 and then connected to the internet with the 360 and any updates are automatically downloaded, or at least they were in my case.
I originally connected the HD Drive to my PC and could not get it to work at all
until I downloaded the drivers from the internet, even then I could not get it to play HD Movies. I cannot get the software player (Arcsoft Totalmedia Theatre, which is supposed to be compatible) to recognize the Drive.
DougieB
