20 GB hard drive on elite
Old 18-06-2008, 10:47 PM   #1
5,444, Level: 17
Points: 5,444, Level: 17 Points: 5,444, Level: 17 Points: 5,444, Level: 17
Thanks: Gave 2, Got 2
i am thinking of getting an elite xbox 360 as my original 360 is on its last legs (rrod). If i get the elite can i connect my original 20gb hard drive in order to copy over all my saved games etc?
Thanks.
Old 18-06-2008, 11:32 PM   #2
3,751, Level: 14
Points: 3,751, Level: 14 Points: 3,751, Level: 14 Points: 3,751, Level: 14
Thanks: Gave 51, Got 62
Re: 20 GB hard drive on elite
i dont see why not!
Old 19-06-2008, 12:16 AM   #3
3,761, Level: 14
Points: 3,761, Level: 14 Points: 3,761, Level: 14 Points: 3,761, Level: 14
Thanks: Gave 6, Got 72
Yeah, you need to get hold of the ms transfer kit though to do it, either via the 'bike' in the 360 forum, or via MS, once you have the elite, make sure to only use the 20gb drive on the elite till you do, as the transfer process wipes the 120gb drive I believe.
