Modding the xbox HD-DVD drive
Old 12-06-2008, 11:57 AM   #1
PhantomICEMAN's Avatar
2,073, Level: 10
Points: 2,073, Level: 10 Points: 2,073, Level: 10 Points: 2,073, Level: 10
Thanks: Gave 6, Got 10
I intially posted this in the wrong section so sorrys guys for the repeat post anways i was looking around the net and i came across and article which basically explained how to connect the xbox HD-DVD dive to you pc but also explained that the HD-DVD drive itself is only a normal sata drive which could possible be taken out of the whole caddy thing it comes in and be put in your pc . That got me thinking , i was wondering now that LG have produced a combo drive that plays both hd-dvd/blu ray movies and is also sata. cant i just remove the existing drive out of the enclosure pop the combo drive and change the bezel and voila id have a xbox drive that would play both blu ray and hd-dvd. my question is would it actually work, oh will xbox software need to be updated with the correct codecs to play blu-rays also.
Old 12-06-2008, 12:08 PM   #2
2,496, Level: 11
Points: 2,496, Level: 11 Points: 2,496, Level: 11 Points: 2,496, Level: 11
Thanks: Gave 18, Got 43
Re: Modding the xbox HD-DVD drive
As far as i'm aware its the 360 that does all the 'faffy' parts such as decoding so I can't see that it would work with just replacing the drive....
Old 12-06-2008, 6:44 PM   #3
1,524, Level: 8
Points: 1,524, Level: 8 Points: 1,524, Level: 8 Points: 1,524, Level: 8
Thanks: Gave 0, Got 4
i can't see the software being able to play blurays......yet. but when the new 360 with bluray onboard then i would imagine the software updates would enable it
Old 14-06-2008, 5:10 PM   #4
tonyadamson's Avatar
2,832, Level: 12
Points: 2,832, Level: 12 Points: 2,832, Level: 12 Points: 2,832, Level: 12
Thanks: Gave 26, Got 31
What new 360? Where did you hear this?
Old 14-06-2008, 6:00 PM   #5
2,384, Level: 11
Points: 2,384, Level: 11 Points: 2,384, Level: 11 Points: 2,384, Level: 11
Thanks: Gave 1, Got 5
You can plug the HD-DVD drive directly into a PC running Vista so the XBox only decodes as a PC would. Although most of the codex that Media Player uses is on the XBox I doubt that they will ever release one that is blu-ray compatable. That is until they give in and release and blu-ray drive add-on. The other option is to put the HD/BD drive into your PC and use Media Centre via XBox to play it on your big TV.
