How do you get 60Hz
Old 11-01-2008, 9:01 PM   #1
4,581, Level: 16
Points: 4,581, Level: 16 Points: 4,581, Level: 16 Points: 4,581, Level: 16
Thanks: Gave 16, Got 20
Question How do you get 60Hz
Want to play Top Spin 2 but won't let me until set to 60Hz
Go into menu as described for Display settings where I should find PAL settings but there is NO PAL settings in menu??????
Connected to JVC32DS6 (32" lcd) via component set to 1080i
Tom
Old 11-01-2008, 9:14 PM   #2
4,581, Level: 16
Re: How do you get 60Hz
Sorted, by switching off xbox and setting av cable to TV to get PAL menu, set to 60Hz then reset back to HDTV
Tom
Old 12-01-2008, 9:29 AM   #3
JIT JIT is offline
7,327, Level: 20
Points: 7,327, Level: 20 Points: 7,327, Level: 20 Points: 7,327, Level: 20
Thanks: Gave 15, Got 9
I get this with a couple of arcade demos that are on the HDD, any idea about a fix i'm using HDMI?
Old 12-01-2008, 12:01 PM   #4
Illustrious Member
30,244, Level: 42
Points: 30,244, Level: 42 Points: 30,244, Level: 42 Points: 30,244, Level: 42
Activity: 29.5%
Activity: 29.5% Activity: 29.5% Activity: 29.5%
Thanks: Gave 53, Got 1,271
Its all covered in the Faq.
Just disconnect the HDMI cable, plug in the original Component/Composite cable, start up the 360, go into the Display options, set the 360 to PAL60hz, turn off the 360, plug in the HDMI cable and away you go.
JIT (12-01-2008)
Old 12-01-2008, 8:15 PM   #5
JIT JIT is offline
7,327, Level: 20
Thanks again, should be another problem sorted.
Old 13-01-2008, 9:18 PM   #6
4,581, Level: 16
Remember the original AV cable MUST be set to TV and NOT HD to get the PAL option settings
Tom
