360 Makes Grinding Noise, Stops Spinning and Crashes
Old 09-01-2008, 11:25 AM   #1
2,910, Level: 12
Points: 2,910, Level: 12 Points: 2,910, Level: 12 Points: 2,910, Level: 12
Anyone else had this problem? After a while, my 360 will make a kind of grinding noise, you hear the disk sound like it's stopped spinning, and then the game will come up with an error message saying the disk cannot be read.
Old 09-01-2008, 11:36 AM   #2
5,566, Level: 17
Points: 5,566, Level: 17 Points: 5,566, Level: 17 Points: 5,566, Level: 17
Thanks: Gave 72, Got 63
Re: 360 Makes Grinding Noise, Stops Spinning and Crashes
I would hazard a guess at a drive fault. Sounds like a phone call to ms?
Old 09-01-2008, 12:38 PM   #3
2,673, Level: 12
Points: 2,673, Level: 12 Points: 2,673, Level: 12 Points: 2,673, Level: 12
Thanks: Gave 6, Got 10
Check the discs... some 360's leave a smeary mark on discs... mine did this with forza
Old 09-01-2008, 4:00 PM   #4
3,760, Level: 14
Points: 3,760, Level: 14 Points: 3,760, Level: 14 Points: 3,760, Level: 14
Thanks: Gave 11, Got 29
Mine does this, I fear its the dvd drive on its way out. I'm not usre if this is covered by the extended warranty that MS issued, as I think this just covers three red lights?
