| Re: Does Xbox 360 Progressive Scan via Component
You may want to take a browse through the FAQ which answers questions like this.
In summary though, I think you're getting progressive scan confused with anti-aliasing issues. Component cables offer the HD resolutions of 720p (the p is for progressive), 1080i and 1080p and depending on what your TV can handle, you can use any of those resolutions. HDMI does not offer a picture quality improvement unless your TV does not handle component well.
The "zig-zags" you see are otherwise known as jaggies, which usually appear on diagonal lines where the pixel edges are visble. This is nothing to do with progressive images, but instead related to resolution and a process called anti-aliasing (or lack of) which smooths out these jaggies.
How noticeable the jaggies are depend on many things, including how close you are to the TV, what resolution you're playing at, how big your TV is and which game you're playing. Sit close to a big screen TV at a low resolution and the jaggies are more noticeable. The best solution is to sit further away, and increase the resolution (though going past 720p won't make much difference). Some games also have more noticeable anti-aliasing and higher resolutions, making jaggies less visible.
Make sure you have the switch on the component cable switched from SD to HD also! (w00t for me being in the 7k club!)
