Dead DVD Drive
Old 30-12-2007, 4:19 PM   #1
3,408, Level: 13
Points: 3,408, Level: 13 Points: 3,408, Level: 13 Points: 3,408, Level: 13
Activity: 2.1%
Activity: 2.1% Activity: 2.1% Activity: 2.1%
Thanks: Gave 21, Got 5
Dead DVD Drive
Hi Folks
My Launch 360 stopped reading discs recently, when it did it would constantly display the dreaded 'Dirty Disc' message. I have since bought a new Elite, question is:
Once I transfer my data over to the new 120gb HD and make sure everything works I was thinking of ripping the Premium to prices and buying a replacement DVD Lense off ebay to attempt a repair. Anyone tried this with any success?
Wouldn't mind putting the old 360 on the back room to use when some crappy stuff being watched on the big telly :P (pity u can't share one saved game space)
Jon.
Old 30-12-2007, 5:15 PM   #2
urz urz is offline
2,980, Level: 12
Points: 2,980, Level: 12 Points: 2,980, Level: 12 Points: 2,980, Level: 12
Thanks: Gave 4, Got 18
Re: Dead DVD Drive
May be easier to replace the whole dvd drive. They seem to be quite cheap on ebay and theres loads on there.
http://cgi.ebay.co.uk/NEW-XBOX-360-T...QQcmdZViewItem
The 360 is resonably easy to take apart as long as youve got the correct torque drivers (think you need T8 and T10).
Heres a guide to show you how to take your 360 apart:
http://www.anandtech.com/systems/sho...spx?i=2610&p=2
Just be care when removing the back part of the 360 as they have tendancies to snap!
There are also many video guides on youtube
Heres one for example:
http://www.youtube.com/watch?v=Vy2pVygQPXM
Progeni (30-12-2007)
Old 30-12-2007, 6:18 PM   #3
3,408, Level: 13
Activity: 2.1%
Re: Dead DVD Drive
Ta for the response and appologies for posting in the wrong section.
I have ordered a Tool kit with the relevant torx drivers and case removal tool. I'll have a look at the drive when that arrive and maybe order a complete new one from ebay.
