| Xbox 360 - HDMI 1080p problems - faulty console?
Hi everyone,
Had my 360 for about a month now. Now this is probably only a minor issue, but I want to see if anyone else suffers from this. I'm not using this setup at the minute - but am considering going back to 1080p output shortly so thought I'd double check.
I had the Xbox360 running through 1080p output, which my TV downscaled to 1680x1050. It's a Samsung 22" TV/Monitor jobby. I played some games on it, and was reasonably impressed with the quality.
However, I then tried to watch films on it. I assume the console is upscaling the SD DVD content to HD 1080p, which is fine. BUT what happens is that about every 10 seconds, the screen is filled with garbage. This happens with ALL of my DVDs (all of which are originals, and the console is in no way modified).
The best way I can describe it is by finding a picture of near identical noise from the internet, which I have uploaded at the bottom of this post.
Does this suggest my console is faulty, or do other people have this issue?
For reference, I was using (for video output):
Xbox 360 Arcade edition, with 256mb memory card and 20GB HDD
Wilko's own brand HDMI lead (not gold plated, but £5 - couldn't complain)
Samsung SM225MW 22" Monitor / TV
At the moment I'm using the VGA output, with a Gamelink cable, basically so I have Phono outputs to connect to my headphone amp. I am querying this 1080p issue though as I am considering getting some decent Component cables instead, which should support 1080p again.
Reason: changed title
