xbox 360 resetting when change channel,using audo plug??
Old 15-09-2011, 4:53 PM   #1
Thanks: Gave 8, Got 18
can any one tell me why my xbox rests itsself if u use my turtle beach x12 connected to the audio dongle if i change channel
its fine if its not connected, but soon as i connect the dongle, i turn over, return to fine its reset.
im using the slim dongle, just taken off outter case so it fits, am wondering it its same on the old style dongle
Old 16-09-2011, 1:54 PM   #2
Thanks: Gave 295, Got 361
I'm not 100% sure if its supposed to do it with the official dongle but if you use a component cable as well as HDMI so you can get optical out, the console will reset. The xbox will detect its lost the handshake with the TV and then because the component cable is connected it will automatically switch to analogue and attempt to use that.
