Weird RROD?
Old 22-11-2009, 2:59 PM   #1
urz urz is offline
2,980, Level: 12
Points: 2,980, Level: 12 Points: 2,980, Level: 12 Points: 2,980, Level: 12
Thanks: Gave 4, Got 18
Weird RROD?
Ive been getting a weird RROD on my 7 month old 60gb. Basically the Xbox cuts out (screen goes pixelated - then turns off) then red rings. But the odd thing is - which i havent had on my previous 3 RROD - is that my TV (Panasonic TX-32LXD60) switches off as well then turns back on? Nothing else on my 8 plug extension lead is effected - wireless router, Hifi, digital clock are all fine? Once i reboot the xbox it will start up again but will then do the same again within around 10mins? Its happened 5 times in a row so far.
Anyone heard of this before or are aware of what has gone on?
urz
Old 22-11-2009, 3:32 PM   #2
8,371, Level: 21
Points: 8,371, Level: 21 Points: 8,371, Level: 21 Points: 8,371, Level: 21
Thanks: Gave 253, Got 285
I'm guessing you're using HDMI in which case it's probably something the 360 sends through HDMI rather than it happening through your extension.
Old 22-11-2009, 3:42 PM   #3
urz urz is offline
2,980, Level: 12
No, ive got it connected via component - run out of inputs on the TV to have the xbox connected via HDMI - would this still be applicable?
Old 22-11-2009, 3:47 PM   #4
8,371, Level: 21
Curious then, perhaps it's just some glitch of a signal being sent with a whacky resolution or soemthing. Not seen that one before myself so it is indeed a weird one.
Old 22-11-2009, 3:51 PM   #5
urz urz is offline
2,980, Level: 12
Likewise? lol. I had a good google search and couldnt find nothing? Not to bothered about the xbox breaking as it gives me a good excuse to buy an Elite - but i was a bit concerned if there was a fault within the TV or even worse the electrics?
