Xbox 360 RROD - First 4 lights then 3 - what does it mean?
Old 21-11-2009, 11:09 AM   #1
189, Level: 2
Points: 189, Level: 2 Points: 189, Level: 2 Points: 189, Level: 2
Thanks: Gave 7, Got 0
Hi there,
When I turn my Xbox 360 on, at first it flashes with 4 out of 4 red lights, then it flashes with 3 out of 4 red lights, what does it mean and is there a cure?
Old 21-11-2009, 11:19 AM   #2
1,430, Level: 8
Points: 1,430, Level: 8 Points: 1,430, Level: 8 Points: 1,430, Level: 8
Activity: 3.7%
Activity: 3.7% Activity: 3.7% Activity: 3.7%
Thanks: Gave 16, Got 14
go to xbox support website that will help you.i dont know how to put links on here,sorry.it could be a powerpack fault or the dreaded ring of death which means its over heated and will need a repair.
Old 21-11-2009, 11:32 AM   #3
189, Level: 2
I've had a brief look there and not seen anything, can you PM me a link?
Old 21-11-2009, 11:49 AM   #4
3,676, Level: 14
Points: 3,676, Level: 14 Points: 3,676, Level: 14 Points: 3,676, Level: 14
Thanks: Gave 2, Got 0
You have the ring of death...
If you bought your xbox less than three years ago from new then you will be able to get it repaired for free off MicroSoft.
Go to xbox support and register your xbox and take it from there..
If your xbox is older than 3yr you can do something called the xclamp repair which involves taking the xbox apart and replacing the xclamps with screws and washers.
Rgrds Jonny
Edit:
This should help you determine what your error is: http://forums.xbox-scene.com/index.php?showtopic=484726
Hope its ok to post links if not mod please remove....
Old 22-11-2009, 3:51 PM   #5
8,371, Level: 21
Points: 8,371, Level: 21 Points: 8,371, Level: 21 Points: 8,371, Level: 21
Thanks: Gave 253, Got 285
4 Red lights is usually the AV cable is not connected properly, or indeed at all. Perhaps you've turned the console on without it connected and it then red ringed after a few seconds?
Old 22-11-2009, 5:41 PM   #6
8,989, Level: 22
Points: 8,989, Level: 22 Points: 8,989, Level: 22 Points: 8,989, Level: 22
Thanks: Gave 710, Got 833
Aye, all 4 is no av cable connected. Check thats in properly first.
