Hello,
Was hoping someone could clear the mind of a confused gamer, well so I'm hoping to soon order a new Xbox 360 after my UK Launch 360 finally went to console heaven. Trouble is I'm hearing all sorts of mixed messages concerning the transfer kit working or not working with the new 250GB hard-drives.
Well I have a second transfer kit that I actually accidentally bought not knowing that my currently used 120GB HDD would come with one. So I was hoping to use that, I believe the issue as to do with the CD. Now I know I have my CD somewhere but I haven't located it yet but to be honest I'm almost 100% sure it won't work as it's a few years old now.
So is there a way to get a updated disc? Strangely the transfer kits seem non-existent nowadays, the only place to buy them is on Ebay and I can't be sure what version of CD they have without asking and confusing the seller
So some advice would be welcomed, originally I was planning not to transfer my data and simply buy a memory unit and obtain a few saves here and there. But if the transfer of the HDD is capable then it's worth a go, especially when I consider my Rock Band 2 DLC and large catalogue, I already suspect that that will be a mess to sort out on a new system.
Thanks!
EDIT!
I've just noticed a thread on this issue so I apologise. Delete if one wishes.
