xbox arcade no dvd
Old 14-11-2009, 7:33 PM   #1
8,709, Level: 22
Points: 8,709, Level: 22 Points: 8,709, Level: 22 Points: 8,709, Level: 22
Thanks: Gave 368, Got 107
xbox arcade no dvd
Recently picked up a arcade from blockbuster. All is good but just noticed that there is no disc with the 5 arcade games. Have they stopped putting it in now?
Old 14-11-2009, 7:58 PM   #2
147,277, Level: 92
Points: 147,277, Level: 92 Points: 147,277, Level: 92 Points: 147,277, Level: 92
Activity: 50.3%
Activity: 50.3% Activity: 50.3% Activity: 50.3%
Thanks: Gave 1,394, Got 2,809
Re: xbox arcade no dvd
if its not marked on the front of the box, with the pacman label etc telling you theres a dvd inside, then no, its not there.
it should be in the side partitions of card though, if its a marked box.
