Xbox Back from repair warranty question?
Old 13-11-2009, 12:21 PM   #1
4,581, Level: 16
Points: 4,581, Level: 16 Points: 4,581, Level: 16 Points: 4,581, Level: 16
Thanks: Gave 16, Got 20
Got a refurbished unit swapped for mine back from repair at MS (original had E74 error).
Anyone know what warranty if any I would get with the refurbished unit, would have preferred to get my old unit back as it didn't have much use and was lovingly cared for.
Tom
Old 13-11-2009, 12:38 PM   #2
5,689, Level: 17
Points: 5,689, Level: 17 Points: 5,689, Level: 17 Points: 5,689, Level: 17
Thanks: Gave 31, Got 103
Re: Xbox Back from repair warranty question?
I *think* it is 90 days, unless it fails with three red ring or e74 error, in which case it's three years. I think you can check warranty status in the support section of xbox.com
Old 13-11-2009, 1:12 PM   #3
4,581, Level: 16
I had thought of that, I'll register it tonight see what it comes back at.
Thanks,
Tom
Old 13-11-2009, 1:51 PM   #4
3,606, Level: 14
Points: 3,606, Level: 14 Points: 3,606, Level: 14 Points: 3,606, Level: 14
Thanks: Gave 40, Got 26
Just got mine back today (e74 repair), original manufactor date was 2007-09-18. so the 3 year warranty should have expired 2010-09-18 but new warranty expires 6-2-2010 giving only 90 days so it seems i'm loosing 7 months warranty.
Only took 7 days from pick up to receiving back.
Old 13-11-2009, 4:11 PM   #5
8,989, Level: 22
Points: 8,989, Level: 22 Points: 8,989, Level: 22 Points: 8,989, Level: 22
Thanks: Gave 710, Got 833
You will get 90 days (3 months as most say) but it *should* still have a 3 year warranty for RRoD and E74 starting preety much from the service date now on the back of your console.
blackadder (13-11-2009)
