Hello,
In need of some Xbox 360 related assistance, well for the fourth time this year I had been fixing my RROD issue with a new set of X-Clamps and heating the motherboard. This as worked perfectly on my European launch system the past few times and it technically as worked fine here to. But there's a new issue to do with my DVD Drive and my SATA Cable.
Upon start up it seems to operate fine, but gets stuck on the splashed Xbox 360 logo start up screen. Eventually the red light of hardware failure appears and tells me that I have the E64 error which according to the web means:
E64: DVD Drive Error - Dvd drive timed out during reset :Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot. also it could mean that the Kernel can't be launched/signature in NAND Flash chip is broken It could be possible after bad update.
http://forums.xbox-scene.com/index.p...;#entry4156375 This might also be caused by a bad SATA cable.
Now I should note that I have
NEVER flashed or messed with my Xbox 360's DVD Drive, I'm not that stupid. So there can only be two reasons why this as started to fail, it can't be due to any interference with the drive as I have not touched that.
1.
The SATA cable is broke, the power up cable works fine it seems but the absolute terrible design of the Xbox 360 does mean that the short and poorly placed SATA drive gets damanged. Plus two of the pins from the motherboard connection broke off a few months back, though it's worked since.
DVD DRIVE IS THE HITACHI-LG.
2.
Something as gone a little odd on the motherboard, now I say this because I tested the motherboard after heating both front and back (with 45+ minutes of cool down) and noticed that upon perfect launch it stated the DVD Drive was 'OPENING' so this might have been the same in the past but I don't recall it saying that.
I also have another issue, SATA cable replacements. The SATA Cable that comes with the Hitachi-LG is rather poor, but finding a replacement could be tough. Especially when you read on the web that they sell 'SATA cable replacements' but don't state which drive it is for. Are there different types of SATA Cables for the different DVD drives Microsoft use? I have another system which as a different DVD Drive and that uses a slightly different SATA Cable to the one in my troubled system so I can't use that sadly.
As you can see I'm in a bit of a pickle, any useful advice would be great.
Appreciated.
