Xbox play on laptop
Old 10-11-2009, 11:17 PM   #1
1,334, Level: 8
Points: 1,334, Level: 8 Points: 1,334, Level: 8 Points: 1,334, Level: 8
Xbox play on laptop
Hi im looking to play my PS3 and soon XBOX on my laptop as well the tv in my room is tiny and rubbish picture so this is more ideal and was wondering if i ran the wire from my xbox to this
USB Type A Male to 3x RCA AV/TV Adapter Lead Cable UK on eBay (end time 09-Dec-09 09:33:44 GMT)
and have some adapters to make the rca cables to female so that it all plugs together would it play on the screen?
Or maybe
USB Capture Card VHS TV to DVD S-Video PS3 Wii XBOX 360 on eBay (end time 05-Dec-09 10:00:42 GMT)
Old 13-11-2009, 12:36 PM   #2
5,672, Level: 17
Points: 5,672, Level: 17 Points: 5,672, Level: 17 Points: 5,672, Level: 17
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 5, Got 164
Re: Xbox play on laptop
no chance with that cable - no idea what that is actually for but its not going to work, analogue video to usb - what the hell !!
The capture card is possible but you need more information - its for recording video clips in low res.
I would expect it to
A - look terrible and be at a low frame rate.
B - possible be displayed in a window and not full screen
C - have some possible lag.
D - possible force you to record while you are playing - filling your harddrive up everytime.
buy a 2nd hand TV, even a old crap one will be better than that - no one uses there laptops for console gaming.
