Help - Hooking up Xbox 360 to a 1080P LCD monitor but only showing 480?
Old 09-11-2009, 8:17 PM   #1
Thanks: Gave 4, Got 0
Unhappy Help - Hooking up Xbox 360 to a 1080P LCD monitor but only showing 480?
Help - Ive hooked up my brand new Xbox 360 elite to a Hanns-g 1080p 28" HG281DP LCD monitor via a HDMI cable but the 360 can only display 480 as all the other options are greyed out?
What the hell??? My PS3 works fine.....?
UPDATE * - Ok luckly I purchased a second identical monitor at the weekend - Ive plugged the xbox upto that and it displays at 1080p. I plugged my PS3 into the second monitor and it knocks the resolution down to 500 something? Huh? So i reconfigure the PS3 and it displays 1080p. SO I try a different HDMI lead and get the same results (so leads are fine).
Right so I set the XBOX 306 to 1080p on my second monitor, unplug HDMI lead and plug into monitor one and its still shows 1080p but when I reset the xbox it reverts back to 408????!!!!! aaaaaaaaaaaaaagh. It makes me think the monitors are not communicating properly but I cant get my head around it.....
