Xbox not working with disc in tray.
Old 07-11-2009, 5:52 PM   #1
1,345, Level: 8
Points: 1,345, Level: 8 Points: 1,345, Level: 8 Points: 1,345, Level: 8
Hey guys, you've probably had this question a million times but here goes anyway...
I played my xbox360 yesterday with no problems whatsoever. However, when I turned the machine on today and put a disc in the drive the console would not recognise that there was a disc in it. I tried a few more games just incase, then I tried the usual turning it off etc but no change.
I guess I just wondered if my xbox is borked or if this is a common problem and what's the best remedy?
Cheers, Stevo
ps - I've had the console about 6-8 months.
Old 08-11-2009, 2:16 AM   #2
19,694, Level: 34
Points: 19,694, Level: 34 Points: 19,694, Level: 34 Points: 19,694, Level: 34
Activity: 15.5%
Activity: 15.5% Activity: 15.5% Activity: 15.5%
Thanks: Gave 649, Got 1,245
Re: Xbox not working with disc in tray.
sounds like the laser in the dvd drive has gone, if its still under warranty just return it and get a new one. if you bought it 6 months ago second hand then its pretty easy to change yourself
