Plugging in an Optical Cable
Old 07-11-2009, 11:37 AM   #1
5,258, Level: 17
Points: 5,258, Level: 17 Points: 5,258, Level: 17 Points: 5,258, Level: 17
Thanks: Gave 51, Got 10
Hi all
Am I being utterly stupid here?!
I have a 360 Elite and have my TV connected to it via a standard HDMI cable. I have just bought an optical cable as I would like to plug a mixamp in but I can not find an optical port on the back?
Is there one or do I have to purchase a dongle type thing?
Old 07-11-2009, 5:16 PM   #2
2,694, Level: 12
Points: 2,694, Level: 12 Points: 2,694, Level: 12 Points: 2,694, Level: 12
Activity: 3.2%
Activity: 3.2% Activity: 3.2% Activity: 3.2%
Thanks: Gave 76, Got 47
Re: Plugging in an Optical Cable
Its on a dongle unfortunatley, did your Elite come in a white box (bought within the last two months) or is it bit older? If its older then a dongle should have been in the box, newer white box and they cost-cut the dongle out
cunnas (09-11-2009)
Old 08-11-2009, 4:33 AM   #3
1,503, Level: 8
Points: 1,503, Level: 8 Points: 1,503, Level: 8 Points: 1,503, Level: 8
Thanks: Gave 3, Got 5
True words, you need the dongle since there is no direct output off the motherboard itself
Old 09-11-2009, 9:18 AM   #4
5,258, Level: 17
thanks, managed to find the dongle!
