Originally Posted by ristac Exactly my thinking.... £500 or so for the Porsche steering wheel or £100 for the G25 and another £200 for a PS3 MMmm |
Think you are looking at the wrong wheel, the wrong website or need to go to specsavers
£500. Do I get a racing suit and shoes as well becasuse for my £329. I can use mine with my PC, Xbox 360 and my PS3.
For this I get all of this: Force Feedback racing wheel with leather wheel rim for Xbox360
Black painted metal shifter paddles
RF dongle for compatibility to PlayStation®3 and PC
Wired pedals with clutch
6+1 speed gear shift
Sequential gearshift
Steel Plate (for pedals)
Power supply
Quick guide
Drilling template
Compatibility:
Xbox360:
The wheel is compatible to all games which support the Microsoft wireless wheel for Xbox360.
The 6+1 Speed shifter is compatible to all future racing games which support this shifter.
PC / PlayStation 3
You can connect the wheel to these platforms with either a USB cable or with the RF dongle (PWTRF)
Pedal compatibility:
Microsoft wireless wheel for Xbox360 pedals (with optional adapter)
Logitech G25 pedals (with optional adapter)
Fanatec Porsche Standard Pedals
Fanatec Clubsport Pedals (optional)
Now not wishing to make you sound mmmmm like you have not done enough research, I think this is pretty good value for a future proof wheel and pedal set.
