AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Operating Systems and Software > Windows Media Center Edition MCE
LinkBack Thread Tools Display Modes
Old 22-11-2005, 12:32 AM   #1 (permalink)
Thanks: Gave 6, Got 18
recommend a usb audio card with spdif out
After hours of faffing i have come to the conclusion that the audigy 2 card just wont output spdif to my receiver properly in my current sff pc, it works on a different pc fine. using the same copy of mce. had to fake a activation (too many hardware changes) but no worries there. dd dts passthru using same codecs.
So i thought i might as well get a usb audio card as long as there are no lip sync issues and install 2nd pci freeview card.
options please
Jon
[size="1"]Meridian Source, Meridian AV , Dynaudio Speakers, DIY Amps, HTPC, Panny Screen.........
JonLeach is offline
Old 22-11-2005, 9:00 AM   #2 (permalink)
Thanks: Gave 8, Got 14
I use an onboard realtek card do they do external cards ?
If so that works fine with MCE and SPDIF
evolution400 is offline
Old 24-11-2005, 10:53 AM   #3 (permalink)
I got myself an audigy 2 ZS USB2 sound card. the SPDIF is pefect out putting DTS and DD to my decoder when watching DVDs. No lip synch issues. i hahad to go this route due to my onboard SB Live causing overheating issues with my Graphics CArd when Gaming. I would recomend the solution
Nathan
Nathany is offline
Old 24-11-2005, 11:03 AM   #4 (permalink)
Thanks: Gave 224, Got 125
I had problems with my onboard nforce2 sound in my shuttle, and I bought a very cheap Creative Live 24bit USB2 card, and not had any problems since. You can use both type of digital out connecters, optical and coaxial.
lisa
lisag is offline
Old 24-11-2005, 11:41 AM   #5 (permalink)
Thanks: Gave 3, Got 5
Create Extidgy is a USB Sound Card
http://www.creative.com/products/pro...07&product=585
jonsayers is offline
Old 24-11-2005, 6:08 PM   #6 (permalink)
Thanks for the replys I will look out for a usb soundcard. Loathed to spend much on it though. Don't know if I should get anothe case n mb with spdif on board and utilize my sff pc somewhere else.
Jon
JonLeach is offline
Old 24-11-2005, 6:47 PM   #7 (permalink)
http://www.pcworld.co.uk/product.php...icerunner_feed
lisag is offline
audio, card, recommend, spdif, usb
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Audio Line In - USB richjthorpe Computer Systems 0 23-09-2005 1:29 PM
Recommend speakers for multi-room / distributed audio?? dealmaker Speakers 10 27-02-2005 8:04 PM
3COM 54g PCMCIA CARD, ADSL USB modem, Nokia HS-1C Camera, ShaunIOW Archive : Completed Business and Expired Threads 13 06-11-2004 12:14 PM
Problems with In-Win CR-i530 Card Reader... IronMonkey Computer Systems 2 04-10-2004 9:59 PM
Audio dropouts using mini-jack to phono leads with SPDIF digi signal dunkyboy Computer Systems 0 02-04-2003 11:46 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
