Thanks Moogle,
When i go to the disc channel there's no icon there - all thats available is the start button down the bottom, the wii menu button, and the scroll left/right buttons..
i have read a bit about the update that is on the disc and i'm pretty sure that was a firmware update - 3.1 or something like that.. my Wii is already at 3.4 so i dont think it should need the update..
will have another play around with it in the mornig
Cheers,
Mick
Originally Posted by Moogle Super Mario Galaxy isn't a dual layer disc so I doubt that is the problem. It's almost certainly due to the fact you have not updated the game as I recall some people having the sam issue when the game first came out and not updating it was the problem. I'm not sure as it has been a long time but I think after you insert the disc and go to the disc channel there should be to icons you can click on. One is the game and the other is the game update. I'm pretty sure this is the issue. Unfortunately the game and the console is not very intuitive regards applying the update. |
