Originally Posted by Bomer 1) Does they come with the jackets (The rubber bits)?
1a) If not, how much are they?
2) Is the "motionplus" part of a wii jacket? :s
3) Where is best/cheapest place to get the Wiimote + motion plus + Nunchuck from? |
1) They all come with a standard jacket.
2) Wii motion+ is a jacket
and the actual motion plus attachment all-in-one.
Your normal remote goes into the motion plus jacket (which is bigger than a normal jacket) and attaches to the motion plus unit which sits in the bottom of the jacket.
3) There are lot's of good places to get these from, just type it into Google and choose "shopping" search, see what comes up.
Hope it helps.
