001 ERROR help!!?!
Thread Closed
Old 28-07-2009, 11:27 AM   #1
Laubi02's Avatar
5,794, Level: 18
Points: 5,794, Level: 18 Points: 5,794, Level: 18 Points: 5,794, Level: 18
Activity: 15.5%
Activity: 15.5% Activity: 15.5% Activity: 15.5%
Thanks: Gave 465, Got 155
001 ERROR help!!?!
hi,
i have got a copy of my fitness coach ntsc to run on my jap wiikeyed machine.
everything looks fine, but pressed play and it came up with some jap text including 001 (im assuming its 001 error)
any idea how to by pass this?
p.s i have no homebrew!
Old 29-07-2009, 5:39 PM   #2
5,793, Level: 18
Points: 5,793, Level: 18 Points: 5,793, Level: 18 Points: 5,793, Level: 18
Thanks: Gave 4, Got 23
Re: 001 ERROR help!!?!
Yes,
Update your Wiikey firmware to version 1.9
Old 30-07-2009, 8:16 AM   #3
Laubi02's Avatar
5,794, Level: 18
Activity: 15.5%
Originally Posted by m4tty1 View Post
Yes,
well on my firmware it says its 4.1j
(tho i never recall updating it - it started to update then i turned it off as i heard from some ppl its not good to update)
Old 30-07-2009, 8:19 AM   #4
5,793, Level: 18
4.1J is the firmware on the actual console not the Wiikey chip.
As stated, upgrade your Wiikey firmware to 1.9 and you will be sorted.
http://www.wiikey.cn/static/download...y.1.9s.JAP.rar
Burn that image to a disc, stuff it in your console, follow on screen instructions.
Laubi02 (30-07-2009)
Old 30-07-2009, 9:10 AM   #5
Laubi02's Avatar
5,794, Level: 18
Activity: 15.5%
thanks mate, will try tonite!
Old 30-07-2009, 7:18 PM   #6
Laubi02's Avatar
5,794, Level: 18
Activity: 15.5%
i just downloaded your file, burned on DVD 2x speed; disc unrecognisable when i play it!!!
do i need to download the "wiikey 2" update?
also, can i burn it on a CD to update?
ahhhh this wii business is starting to **** me off!!!
Old 31-07-2009, 3:28 PM   #7
5,793, Level: 18
Firstly, no need to burn at 2x ever.
Stick to 8x.
So you downloaded the Rar file, opened it, extracted the .ISO file to your PC and burnt the ISO file ?
And you have Wiikey 1, nothing Wiikey 2 will work so completely ignore it.
Wii's will not read CD's ever.
This is super simple mate, nothing technical.
Old 31-07-2009, 3:43 PM   #8
Laubi02's Avatar
5,794, Level: 18
Activity: 15.5%
Stick to 8x.
i know, this is why im super confused!!!
i unzipped it, out came a 1.9s iso file, burnt it on DVD (sony dvd-r) and when i play it, it just somes up with one big question mark!! what am i doing wrong!?!?!?
so whats wrong with wiikey 2 as when i just type that website in, thats all they have under resources, couldnt find where you got the 1.9 from.
Old 31-07-2009, 7:02 PM   #9
5,793, Level: 18
What program did you burn the ISO file with ?
Old 01-08-2009, 1:46 PM   #10
Laubi02's Avatar
5,794, Level: 18
Activity: 15.5%
used nero startsmart - img burn
ive just tried your file again and the "config" 1.9s one too! both dont work!!
is it anything to do with my firmware being 4.1j?
Old 01-08-2009, 7:39 PM   #11
5,793, Level: 18
Are you anywhere near Birmingham ?
Old 03-08-2009, 11:39 AM   #12
Laubi02's Avatar
5,794, Level: 18
Activity: 15.5%
ahhh really apreciate the gesture but no where near. im in southampton!
ive even tried different region updates as someone suggested my chip could be set to a differentr region for some reason.
its like im burning them wrong or something cos the wii dont even recognise the disc and struggles ti read the actual disc!
do i need anyhting besides the 1.9s iso file?!
do i need homebrew? usb stick?!
Old 03-08-2009, 12:04 PM   #13
DazzaSammy's Avatar
8,391, Level: 21
Points: 8,391, Level: 21 Points: 8,391, Level: 21 Points: 8,391, Level: 21
Thanks: Gave 19, Got 113
It could be your laser has died, not uncommon with some wii's.
Try using USB Loader GX on a USB Hdd or USB stick and see if it loads.
Downloads ‎(USB Loader GX)‎
Then youll know if you have a software/firmware issue or hardware issue.
001 error = unidentified hardware. It could be that you need to Trucha sign the iso, or it could be a burning/media issue. Nero maybe setting the layerbreak wrong.
Do original games work?
Try installing the Homebrew channel and ruuning a game from Usb loader there, or neogamma etc.
Old 03-08-2009, 12:51 PM   #14
Laubi02's Avatar
5,794, Level: 18
Activity: 15.5%
all my other old games still load so its not a hardware issue im guessing.
its just the update discs just doesnt want to be read!!
ive burnt many games using the nero img burn like wariware and it works fine!
Old 03-08-2009, 1:30 PM   #15
DazzaSammy's Avatar
8,391, Level: 21
Is it showing up as a Gamecube game in the disc channel at least, or nothing at all?
Old 03-08-2009, 1:51 PM   #16
5,793, Level: 18
PM me your address and I will send you the disc ready burn't.
There is not a layer break issue as it is a single layer.
Stuff Nero, stick always with IMGBurn.
The Jap.ISO file is all you need.
Old 03-08-2009, 1:53 PM   #17
Laubi02's Avatar
5,794, Level: 18
Activity: 15.5%
nope, on the disc load screen (with wii and gamecube disc logos), i enter the disc, disc reader makes feeble noise and then the big question mark comes up!!
03-08-2009, 2:53 PM--------------------------------------------------------------------------------------------------------
ahh m4tty you are a kind man!
do you have paypal? let me give you a couple of quid!
i know its not much but just for the postage at least!
11-08-2009, 9:24 AM--------------------------------------------------------------------------------------------------------
hi m4tty, when did you send the disc as i have yet to receive it (sorry, not pressuring you - just wondering) and also, do you use vertibatum discs? as someone suggested i use them? if you use them then it'll save me buying some!
Last edited by G a f f e r; 10-09-2009 at 6:09 PM. Reason: merged multiple bumps into one
Old 11-08-2009, 11:57 AM   #18
G a f f e r's Avatar
15,929, Level: 30
Points: 15,929, Level: 30 Points: 15,929, Level: 30 Points: 15,929, Level: 30
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 192, Got 341
Hi guys. Please have a quick gander at the trading rules.
Offering a disc for free is fine but when money is offered in return I think this then has to then go via the trade forums.
Cheers.
Old 19-08-2009, 11:15 AM   #19
Laubi02's Avatar
5,794, Level: 18
Activity: 15.5%
hi m4tty, just wondered any updateon that update disc before i give up
21-08-2009, 4:06 PM ------------------------------------------------------------------------
25-08-2009, 2:39 PM ------------------------------------------------------------------------
i assume theres no disc arriving m4tty?
also, can anyone please confirm that i do not need to burn the iso of both the update disc AND the config disc together?
28-08-2009, 12:10 PM ------------------------------------------------------------------------
HELP""!!>!?!?!
also, i hope you have been too busy to send the disc m4tty but you have been on 2 weeks after you promised to send it. i dont mind you not wanting to send it as it is a free egsture in the end of the day but i am very wary about giving you my home address for no reason!
Today, 3:12 PM ------------------------------------------------------------------------
Last edited by G a f f e r; 10-09-2009 at 6:13 PM. Reason: Multiple (spam) bumps removed
Old 10-09-2009, 6:07 PM   #20
15,929, Level: 30
Activity: 1.4%
@Laubi: Please stop spamming the thread with repeated bumps. It appears that m4tty1 has kindly decided to send you what you need free of charge, so if there is an issue with this I suggest you pm him directly rather than clutter up the board.
I will tidy up and close this thread for the time being.
If at a later date you cannot source the disc after all and wish to reopen this thread/explore and discuss other avenues, please pm me and I'll re-open it.
Thanx
Thread Closed
Powered by
 Latest popular product prices
Nintendo Wii Blue
5 prices from
 £107.95 Click to show/hide the offers
Nintendo Wii Blue
5 prices from
Nintendo Wii White
12 prices from
 £109.99 Click to show/hide the offers
Nintendo Wii White
12 prices from
Nintendo Wii Black
11 prices from
 £114.99 Click to show/hide the offers
Nintendo Wii Black
11 prices from
Nintendo Wii Red
1 price
 £197.93 Click to show/hide the offers
Nintendo Wii Red
1 price
 Updated February 12th at 5:30am. Prices include delivery.
