Router woes with Mario Kart - Anyone help?
Old 10-02-2009, 1:56 PM   #1
5,554, Level: 17
Points: 5,554, Level: 17 Points: 5,554, Level: 17 Points: 5,554, Level: 17
Thanks: Gave 7, Got 2
Hi All
Hoping somone here can help.
I've got a zyXEL NBG318S router which works fine with the PC(s), laptop and PS3. However when connecting with the Wii for Mario Kart the connection drops after around 7mins with a 91010 error. I've tried this wirelessly and via a lan adapter with a cable directly to the router. Both times I hit the same error. When I connect directly to the modem all is fine and no errors. So I am assuming that the problem lies in the router with a bit of missed configuaration.
Does anyone have any suggestions. I'm trying to get an answer out of zyXEL but have had no response yet.
Kev
Old 13-02-2009, 1:16 PM   #2
5,554, Level: 17
Re: Router woes with Mario Kart - Anyone help?
Finally heard back from the support people. I've got a code to telenet into the router that should fix it. Common problem with the NBG series apparently.
Update:
Entered the code earlier and everything now seems to be fine :-)
