Shaun White Snowboarding question
Old 02-10-2009, 6:18 PM   #1
2,728, Level: 12
Points: 2,728, Level: 12 Points: 2,728, Level: 12 Points: 2,728, Level: 12
Thanks: Gave 72, Got 21
Hi all,
A quick question if you have the above game. Sometimes when landing it results in lines appearing across the screen - only there for a very short time. Is this some kind of effect built into the game? Is it supposed to be interference from the camerman following you filming or do you think there is a fault with my copy of the game? As I say it only happens now and again when jumping - it does not happen at any other time.
Thanks in advance for your help.
Old 12-10-2009, 2:50 PM   #2
SFBanks's Avatar
1,708, Level: 9
Points: 1,708, Level: 9 Points: 1,708, Level: 9 Points: 1,708, Level: 9
Thanks: Gave 24, Got 52
Re: Shaun White Snowboarding question
I just got this game also and noticed the same lines. I just assumed it was an effect from the cameraman following behind.
