Is my motion plus faulty
Old 24-06-2009, 6:48 PM   #1
5,866, Level: 18
Points: 5,866, Level: 18 Points: 5,866, Level: 18 Points: 5,866, Level: 18
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 178, Got 331
I am getting increasingly frustrated with Grandslam tennis and I'm beginning to think that the motion plus is faulty. I've watched the videos about holding the controller facing the ceiling and letting it sit flat to reset.
The screen simply does not reflect what I'm doing with the controller and the player often does not even move ( especially left baseline backhands) when I want it to. I've seen a video of a chap swinging his racket from left to right and rolling the racket between his hands.......I can't do either !!!
Old 25-06-2009, 9:14 AM   #2
3,641, Level: 14
Points: 3,641, Level: 14 Points: 3,641, Level: 14 Points: 3,641, Level: 14
Thanks: Gave 24, Got 16
Re: Is my motion plus faulty
If you haven't already, it might be worth trying a system update. You need the latest firmware for the motion plus to work properly.
Eurogamer originally gave Grand Slam Tennis a bad review as they had the same problem:
Editor's blog: Grand Slam Tennis to be re-reviewed // Blog entry /// Eurogamer - Games Reviews, News and More
BISHI (25-06-2009)
Old 25-06-2009, 10:08 AM   #3
5,866, Level: 18
Activity: 6.1%
Ok, thats promising. Do I do this in the Wii set up menu ??
Old 25-06-2009, 10:20 AM   #4
2,904, Level: 12
Points: 2,904, Level: 12 Points: 2,904, Level: 12 Points: 2,904, Level: 12
Thanks: Gave 27, Got 15
Yep there is a system update option in there, this link is pretty helpful;
| Nintendo - Customer Service | Wii - Wii System Update
In my experience if you need an update, you get prompted by the pulsating blue light but it's certainly worth a try.
BISHI (25-06-2009)
