AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > VoIP Internet Telephony
Compare Broadband – Broadband FinderCompare Broadband – Broadband Finder
LinkBack Thread Tools Display Modes
Old 18-01-2006, 5:47 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Bluetooth for Mac
Does anyone know if there is a Skype Bluetooth headset that works with Mac? Everything on the market is for Microsoft, even Apple seems to have missed out on this particular lucrative market.
jacking is offline
Old 26-01-2006, 3:25 PM   #2 (permalink)
Thanks: Gave 10, Got 2
Smile Bluetooth for Mac (headset for Skype)
Hi Jacking, as long as you are on MAC OsX 10.4 (Tiger) and have bluetooth built in to your mac (if not you can use a Bluetooth USB dongle (i use the D-Link DBT 120)
Then go and buy one of the Jabra range of Bluetooth headsets that are used for mobile phones (thats what mine is used for too!)
All you need to do then is turn on the Macs Bluetooth in system Prefs and then PAIR the headset (you will need to put the Jabra headset into Pairing mode, just hold down the on/off button on the headset untill the led goes soild) and Mac together (again in bluetooth setup - Add a new device click on headset & follow the instructions)
When they are both paired together then open up audio prefs in Skype and choos the Jabra device as input and output.
Then you should be able to talk hands free.
Hope this helps
Madonmacs
MADONMACS is offline
jacking (27-01-2006)
Old 27-01-2006, 6:59 PM   #3 (permalink)
That certainly is very helpful. I'll get one this W/End if possible. Thanks very much
jacking is offline
bluetooth, mac
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
