| Re: Recording from V Box
First of all, you can't use a Freeview box to get "Freeview" channels from a cable connection. They are totally different systems. You can only use the DVD-R to record whatever is coming through the V box
Here is one of several possibilities for connecting the boxes.
1. SCART cable from "TV" output on V box to SCART 1 on TV (set it to RGB instead of composite) as it will give a better picture.
2. Another SCART cable from "VCR" out on the V box to the SCART "IN" on the DVD-R (this one will have to be composite as the V box will only do composite from this socket - if you want RGB , get a multiway SCART adaptor and plug the single end into the TV output on the V box and then plug the cable to the TV and the cable to the DVD-R into the multi end )
3. Another SCART cable from the DVD-R SCART "OUT" to SCART 2 on the TV.
4. Aerial lead into "RF IN" on DVD-R and then another from "RF OUT" on DVD-R to the normal aerial socket on the TV - might not be much point in this bit if the normal TV signal is unwatchable.
Note that with a normal V box ( as opposed to V+) you can only get one channel at a time so, if cable is all you have, you need to watch what you are recording.
