BBCI-player
Old 30-07-2008, 12:25 PM   #1
3,234, Level: 13
Points: 3,234, Level: 13 Points: 3,234, Level: 13 Points: 3,234, Level: 13
BBCI-player
I've recently upgraded from the standard V box to V+ box. Preiously on the old V box I could access the BBC I player using the red button when on a BBC channel.
However pressing the red button on the V+ box on BBC channels does not bring up the I-player. Is this the case?
Old 30-07-2008, 12:37 PM   #2
3,793, Level: 14
Points: 3,793, Level: 14 Points: 3,793, Level: 14 Points: 3,793, Level: 14
Thanks: Gave 28, Got 34
Re: BBCI-player
No it should work in the same way. Sometimes after an installation it can take a few hours for all of the services to start working again. If it's been over 1 day then give customer services a call.
Old 30-07-2008, 10:13 PM   #3
3,660, Level: 14
Points: 3,660, Level: 14 Points: 3,660, Level: 14 Points: 3,660, Level: 14
Thanks: Gave 1, Got 3
Re: BBCI-player
The iplayer on Virgin is a little slow to scroll through the menus. They need need to Virginise the GUI...
