| Re: New HD LCD TV - Virgin box - connect?
Firstly optical carries audio only, you should use this to connect you V box to your home cinema kit for audio. A standard V box (Samsung?)can only be connected to your TV via scart. Ensure that the scart output on your V box is set to RGB (makes a big difference. Does the home cinema system have an input pass through scart that is RGB enabled? If so you may get better results connecting the V box via the home cinema system. This may not be the case as in one instance the TV upscales and in the other route the Home Cinema system upscales and since both are Samsung the upscaling is probably identical.
A V+box does not cost £150 This is just one way of getting a V+box. This payment is a single up front one off rental charge. Alternatively you can pay a £30 install fee and a monthly rental.
Edit
Just seen WGlovers post and agree SD via V+ and HDMI at 1080i is excellent. (Panasonic 37LZD85) I also have a standard V box and picture via RGB scart whilst not as good is as good as any other non upscaled input.
