Capturing SD Content On V+ via USB stick?
Old 20-07-2008, 6:20 PM   #1
twobells's Avatar
6,295, Level: 18
Points: 6,295, Level: 18 Points: 6,295, Level: 18 Points: 6,295, Level: 18
Thanks: Gave 6, Got 8
Hey All
My dad loves boxing but refuses to subscribe to yet another non-SKY channel after paying for a zillion SKy channels, I however get it free on my VM package.
I out to my tv from the V+ HD reciever via HDMI atm, and wanted to capture these matches for my pa and realising that the V+ has a USB output thought perhaps I could use this:
http://www.novatech.co.uk/novatech/s...tml?LEA-VC100U
Just capture the content, plug into the pc and burn to dvd-r.
Anything wrong with that idea?
For example does the V+ recognise these usb capture sticks?
best wishes
tb
Old 20-07-2008, 6:29 PM   #2
twobells's Avatar
6,295, Level: 18
Re: Capturing SD Content On V+ via USB stick?
Ok, I have subsequently learnt that [typically] the USB port is non-functional due to lack of firmware support.
Is there any way I can capture SD content without resorting to huge dvd-r setup recorders via scart output?
tb
Old 20-07-2008, 8:15 PM   #3
16,091, Level: 30
Points: 16,091, Level: 30 Points: 16,091, Level: 30 Points: 16,091, Level: 30
Thanks: Gave 38, Got 205
You could use a TV card on a pc to capture it that way.
Old 20-07-2008, 11:12 PM   #4
Chilly Willy's Avatar
2,916, Level: 12
Points: 2,916, Level: 12 Points: 2,916, Level: 12 Points: 2,916, Level: 12
Thanks: Gave 9, Got 79
Smile Re: Capturing SD Content On V+ via USB stick?
tb
Hi twobells,
Let me explain how you may capture SD content. Firstly you will need:
A laptop or PC with a DVD burner
A Scart adaptor see here
A Leadtek VC100 U USB Video Capture stick.
Next you will need to record the boxing programme onto the V+ HDD.
Whenever you want to transfer the programme to laptop/PC for burning to DVD. Connect the scart adaptor to the video scart socket on the V+ box and connect the cables that came with the Video capture stick to the adaptor.
If not sure what I am saying, see the quick guide found here.
The rest I will leave to you if you do purchase the video capture stick.
Hope this has helped
